On the end of my toolpath subs I give a block number return callout
O4022
(NO.4 CENTER DRILL)
N0220 G00 G90 X-2.951 Y5. (B0.) G54P[#900]
N0230 G43 H17 Z.75 S10000 M[#933]
N0240 G98 G82 Z.0381 R.35 P6 F60.
N0250 X-5.549
N0260 X-4.25 Y2.75
N0270 G80
N0280 G00 Z4.43
N0290 M99P#192 <<<<<<<<<<<<<< M99 return to block callout
The sub returns to block N413 in this example
N412 WHILE[#534EQ1]DO1 (SURFACE 2)
IF[#172EQ5301]GOTO501
IF[#172EQ5303]GOTO413
IF[#172EQ5304]GOTO413
#900=[#539+[4-1]]
#192=413<<<<<<<<<<<<<<<<<<<<<<<< defining variable
G91 G00 X0 G54P[#900]
G90 G00 B0.
GOTO602
END1
N413 WHILE[#531EQ1]DO1 (SURFACE 3)<<<<<<<<<<<< program returns to sub
IF[#172EQ5302]GOTO501
IF[#172EQ5305]GOTO501
#900=[#539+[1-1]]
#192=501
END1
GOTO501
N601 M98P[#170+1]
N602 M98P[#170+2]<<<<<<<<<<<<<<<<program leaves sub/ Vericut returns here
N603 M98P[#170+3]
N501
M99
Vericut returns to this sub right from where it left. What do I need to add to my M99 Word/Address to tell Vericut to return to the sub block number?
Tim Johnson
CNC Programmer
LECO Corp.
VERICUT 7.0.3 (64)
Tim,
Not sure if you still need this.
Right or wrong how I do it is...
In the registers, Set
WORD_VALUE "P" {
COND_AND "M" "99" {
VARIABLE "6000"
In the M_misc, set
WORD_VALUE "M" "99" {
COND_AND "P" {
MACRO "EndSub"
MACRO "GotoJumpForwardBackwardStart" {
OVERRIDE_EXP "#6000"
MACRO "EndSub"
Hope this helps
Clayton
