Hello CGTech team.
The Embraer IT guys tried to install Vericut in a IBM - AIX workstation. Follows the report below:
root-rs35pr:/mnt/cgtech/vericut-6.0.2>./install.ux
CGTech Software Installation Program
Copyright, All Rights Reserved
Creating temporary CGTech Installation directory /tmp/cgtech_install...
Creating CD file links in temporary CGTech Installation directory /tmp/cgtech_install...
The following Java version will be used to install VERICUT:
java full version "J2RE 1.2.2 IBM build ca122-20010313"
Preparing to install...
Extracting the installation resources from the installer archive...
Configuring the installer for this system's environment...
Launching installer...
Invocation of this Java Application has caused an InvocationTargetException. This application will now exit. (LAX)
Stack Trace:
java.lang.NoClassDefFoundError: sun/awt/motif/MToolkit
at java.lang.Class.forName1(Native Method)
at java.lang.Class.forName(Class.java:134)
at java.awt.Toolkit$2.run(Toolkit.java:512)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Toolkit.getDefaultToolkit(Toolkit.java:505)
at java.awt.Window.getToolkit(Window.java:432)
at java.awt.Frame.addNotify(Frame.java:279)
at com.zerog.ia.installer.LifeCycleManager.f(DashoA8113)
at com.zerog.ia.installer.LifeCycleManager.g(DashoA8113)
at com.zerog.ia.installer.LifeCycleManager.a(DashoA8113)
at com.zerog.ia.installer.Main.main(DashoA8113)
at java.lang.reflect.Method.invoke(Native Method)
at com.zerog.lax.LAX.launch(DashoA8113)
at com.zerog.lax.LAX.main(DashoA8113)
:? This Application has Unexpectedly Quit: Invocation of this Java Application has caused an InvocationTargetException. This application will now exit. (LAX)
Removing temporary CGTech Installation directory /tmp/cgtech_install...
CGTech Software Installation completed: Wed Jan 3 12:05:08 GRNLNDST 2007
Thank you and best Regards from Brazil,
Daniel Krabbe
Embraer
São José dos Campos, Brazil
A silent installation fixed the problem. Instructions on how to proceed can be found in VERICUT on-line help: Goto V60 Help>VERICUT INSTALLATION GUIDE>Installation>Other VERICUT Configuration Tasks>Using silent Install Mode
