#1 2006-08-03 12:34:25
p-cnc
V6 Slower than previous Version
Good morning all,
We have some Usr file created in V5 than open it in V6, It look too slow compared to V5. Maybe We did something wrong here. Anybody else see same problem.
Hardware P4 2.66GHz with 2GB Ram
WinXPSp2
Thanks in advance
Pat
#2 2006-09-16 01:19:29
DreamChaser
Re: V6 Slower than previous Version
Yes!
We created our user file at V544 and it turn slow when running on V602.
The delay is much significant on turning operation.
Wish you have a nice day smile
DC
#3 2006-10-05 20:00:39
DWARD
I also find that the lathe side is slower. I would be very interested to know if you found a solution !
smile
TY
DW
#4 2006-10-06 16:28:20
It might be worth sending the 5.4 User File and the 6.0 Project file to Tech Support, it might be a configuration issue, they could advise you.
We have done many improvements with the spindle logic in 6.0. some of them require changes to the control setup. If your control is available in the Library folder, I would try to run the files with the 6.0 Library control.
As part of our QA effort, we conduct many performance test and we have not seen a loss in performance in 6.0. When we conduct the test, we run all the test files from a local drive to avoid delays caused by a network connection.
#5 2006-10-16 11:18:54
p-cnc
Good day,
After tested many setting, We found out the problem, It is a license problem. We run same project file and same hardware in two computers with different license
Computer with Machine-simulation license run faster (should be)
Computer * WITHOUT*  Machine-simulation license run 10X slower
We hope someone can test samething and please feed back.
Pat
#6 2006-10-16 13:33:01
Could that be the No license message going to the logger, slowing it down.
Is that Vericut run with a Machine?
#7 2006-10-20 14:50:48
p-cnc
The project file has Machine defined, But in machine setting page, we unckeck box "machine simulation on" and use workpiece view
Pat
#8 2006-11-22 18:33:41
stpendl
Pat
I had the same issue once with V5 and was told to remove all the machine simulation options from the user file, if I don't do machine simulation.
This has speed up things notably and I have never had any speed issues after that.
#9 2006-11-22 19:27:33
ElyW
We did discoverer a problem with V6.0.2 slowing down when no machine simulation license is available.
This slow down problem had been fixed in v6.0.3 and is available on our FTP site.
For 6.0.3 via FTP download...
1.  Complete the on-line form and select "Password for the zip file on FTP site." A password for the password-protected Zip file on the CGTech FTP site will be emailed to you within 24 hours.
2.  Then download ftp.cgtech.com/Download/pointrel/windows/603.zipfrom the FTP site. The file contains the Windows installer files (same files as on the CD). Unzip these files to a local drive and run install.exe.
#10 2006-11-29 11:34:26
p-cnc
It work great on V6.0.3
