I HAVE TREE PROBLEM WITH VERICUT,I HAVE NOT A GOOD FEELING WITH IT !
1) I CAN'T SEE THE TOOL IN MACHINE WIEW WHEN I START THE MOTION.
2) IN THE WINDOW WORKPIECE TRERE IS NO MOTION.
3)VERICUT SHOW THE ERROR "CANNOT LOCATE SUBROUTINES NONE FOR CALL "
THANK YOU FOR YOUR INTEREST!
BYE BYE
Hi Manu,
I'll try to give some short answers to your questions.
Not very easy since I don't know what kind of machine or control it is but here it goes.
1) Do you have any value in column "Gage Offset" in tool manager? If not your tool will be mounted "inside" the spindle.
2) Check the "Display holders in workpiece view" under Setup/Motion. Perhaps "no Animation" i checked there also. If so - uncheck.
3) Most likely you have a word with the letter "L" inside it which you haven't defined. Look in "Setup/control/Word Address" to see which word that has the CallSub or CallSubName macro attached. Most often it is "L".
Svante
Svante Eriksson
System owner
HELLO SVANTE
YOU HAVE BEEN SO FRYENDLY TO ANSWER AT MY MESSAGE BUT IT'S NOT BEEN GOOD FOR ME.
YOU SAID THAT WITHOUT KNOW NC CONTROL USED , WAS VERY DIFFICULT HELP ME.
I USE NC CONTROL "FAN 210IM.CTL" WITH THE MACHINE "NUM TURN.MCH"
THANK YOU VERY MUCH!
Hi Manu
I think the best way to solve your problems is to send an email with a back up of your simulation attach to support.italia@cgtech.com or call 0422405804
Massimo
