Is it possible to print out the Constant Gouge Check "topigraphical" image as a .jpg? Sort of the same as you can do with the "view capture" feature with the cut stock... Maybe this post should be in the feature suggestion area?
Possibly the most obvious tip: I cannot open other windows(like the Vericut Forum page ) or multitask while the simulation is running in CGC... for me, it returns an error when I try to generate a CGC report/ "topigraphical" map later on
Nathan
The only AUTODIFF method that allows you to see the gouges with different colors based on the depth is to do an AUTODIFF with the Surface method after the simulation. The Constant Gouge Check only displays the gouges in red.
In Constant Gouge Check mode, you can stop the simulation at any time, turn it off, reset the gouge check results and do an AUTODIFF by Surface method and it will give a "topographic" display of the gouges.
You can capture the view at any time, it is only a screen shot.
so if i understand correctly, i have to edit the video in some studio software to create an image of the end?
Nathan
no,
File > Images > View Capture...
Output
i did that but it only gave me the cut stock not the CGC result
maybe i did something wrong in the first shot... i'll try it again later
thanks
Nathan
