More control capability on the slider is something we have been asking for on many revs. Making it constantly active and on the main screen in 5.4x is a big improvement.
We think the slider should be the full width or length of the window for more control and go from 0 motion to 100%. This would eliminate the problem of controlling speed each time we upgrade a PC or change revs.
Changing setup values, window size etc to get the system to slow down is not a good workaround in our opinion.
Vericut 6.0.x with the addition of the Motion | Min/Max Motion Dist have improved the control of the slider bar.
Still need min/max control for the ROTARY components of the machine display. Tool change arms, pallet shuttles, rotary axis etc. The min/max motion distance seem to only effect XYZ. We would like to have some control of the Rotary min/max to help minimize AVI file sizes and keep them from "slowing" at tool change, pallet shuttle etc. Currently most rotary motion appears to be around 30 degree intervals.
There is a setting in Configuration, Control Settings, Rotary called Output Intermediate Points. Setting this to NO will cause rotary table motion to be 1 motion, without Vericut putting in intermediate points. Another ER has been listed to add this to the Motion page.
I have ask for a while, for 0-100 be finer 0-10000, or 0 to 99.99 8)
AND
a display of the percentage
AND
a way to key in the precentage. IE 94.67
I have found 92-100 is where the real usable value is
I messed with adduser files, with the
MAXIMUM_DISTANCE_PERCENT MAXDISTP 93
last time i checked, that worked some of the time, to get an exact number.
what say you?
