#1 2007-05-23 16:32:54
m74uk
MDI Functionality
Can we have some of the functionality of MDI back as in v5.4.
I use it a lot to check the position of datums ie G54-G59 when I'm setting up in conjunction with the Driven Point. In v5.4 you just entered the MDI command, pressed Play and everything worked as expected. If you wanted to repeat a command all you had to do was double-click on it and it did it.
Now, you have to press Enter (no big deal) but every command results in a error messege if you don't have Machine Simulation. If you want to repeat a command, you can't double click anymore. I can't even get the Play Selected NC Block to work. If I want to repeat a command I ALWAYS have to re-type it in.
Can someone else try this just with the Verification option and Auto-Diff please to see if they find the new method workable.
M74uk
