The following only applies if you are running the VERICUT license server on a Windows 64 bit operating system. It does not apply if you are running VERICUT on a windows 64 bit system, but the license server is on a different platform.
VERICUT 6.1.1's install for Windows 64 bit has an incorrect version of the SentinelLM license server (8.0.2). This version may produce the following error when attempting to add VERICUT license keys to the server:
"Error [19]: Unable to Add Licenses"
The correct version is supplied with the 32 bit VERICUT 6.1.1 installation.
To correct this problem do the following:
1. Remove the license server service if you installed one.
2. Copy this file to your computer:
ftp://ftp.cgtech.com/Download/pointrel/ … se_805.zip
3. Unzip its contents into into the ...\windows64\license folder, replacing files as necessary.
4. Reinstall the license server service if needed.
