I seem to be having a problem with tooling info not
showing when using the Vericut.VC template,or any template
come to that when creating a report from the file menu :?
The same info however does show when creating
a report from the tool manager.
Any Ideas ?
Regards JonK
Cheers Jon
I guess not ![]()
Cheers Jon
From Menu bar go to Project > report > report template > edit
and then open your template.
1. Double click at tool summary table, Vericut will show table windows.
2. Cilck ADD button and change it to tool thumbnail.
3. You can adjust pictue size by check on in Thumnnail width and Heigth
and specify pixels.
DechakoRn
Application Engineer
Engineering System Solution (Thailand) Co,ltd
