#1 2007-02-21 11:53:36
sae
Substitute
Hi!
Is it possible to use wildcards in Adv. Control Options Subs. Tab
Regards/sae
#2 2007-02-21 18:14:33
Re: Substitute
The substitution is simply a text to text replacement. You cannot use wildcard or conditions.
What are you trying to achieve? maybe there is another solution?
#3 2007-02-22 05:20:08
sae
Re: Substitute
Hi Serge!
In this case i want VCut to ignore Heidenhain tol.  and repl. with nothing .
  ex.     N1110 G62 T0.05 P01 0 P02 5.
  parametres after G62 can have a lot of diff. values .
Maybe there is a more clever solution for this instead of using substitute ?
Regards/sae
#4 2007-02-22 09:22:55
danr
Re: Substitute
Depending on what you want to acheive (Forgive my lack of understanding of the Heidenhain!) there are two possibilities.
@ It seems to to me that you could use the conditional field in your control:
E.g under the T word have a conditional that reads 'And Word G62' and then under that have an override value of T0
This could be repeated for any other parameters
@ Alternatively to ignore everything after the G62 you could substitute for G62 followed by a begin comment symbol:
E.g if ; is the symbol for begin comment:
Substitute G62 -> G62 ;
Cheers...Daniel
Current version: Vericut 7.0.3
#5 2007-02-22 09:43:42
sae
Re: Substitute
Thanks for your help!
Substitute  G62 ->  ;
                                   works perfect
Regards from a cold and snowy Sweden/sae
#6 2007-02-22 21:23:40
Re: Substitute
I personnaly don't like substitution, I use them as a last resort when there is no other way.
It works, don't get me wrong. But when I debug a control, I first look in the Word/Address to see how it is configured. The substitution bypass all that.
For your case, I suggest a different approach:
In Word/Address, set T, P01 and P02 with a condition of G 62 to call the macro named IgnoreMacro. This macro does absolutly nothing but gives you the indication that it is voluntarely ignored.
IMO a cleaner solution.
#7 2007-02-23 11:01:05
sae
Re: Substitute
Hi , thanks for your answer !
I will try this solution also .
Regards/sae
