#1 2006-12-13 19:57:38
stpendl
V6.0.3 crashing when selecting AUTO-DIFF Report on WinXP x64
If I try to display the AUTO-DIFF Report from within Vericut 64-bit on Windows XP x64, VERICUT crashes.
I will try to create a test case and send it to the support.
Here is the hs_err_pid472.log:
# An unexpected error has been detected by HotSpot Virtual Machine:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000000af087f4, pid=472, tid=2164
# Java VM: Java HotSpot(TM) 64-Bit Server VM (1.5.0_06-b05 mixed mode)
# Problematic frame:
# C  [CGTech.dll+0x2187f4]
---------------  T H R E A D  ---------------
Current thread (0x0000000001bdb4b0):  JavaThread "AWT-EventQueue-0" [_thread_in_native, id=2164]
siginfo: ExceptionCode=0xc0000005, reading address 0xffffffff98dab088
Registers:
EAX=0x000000000acf0000, EBX=0x000000006bc7b0c0, ECX=0x00000000074b0000, EDX=0x000000000af087eb
ESP=0x00000000090eeb60, EBP=0x0000000000000001, ESI=0xffffffff98dab088, EDI=0x0000000000000001
EIP=0x000000000af087f4, EFLAGS=0x0000000000010286
Top of Stack: (sp=0x00000000090eeb60)
0x00000000090eeb60:   0000000000000007 00000000074f1330
0x00000000090eeb70:   ffffffff98dab088 0000000000000001
0x00000000090eeb80:   00000000090eee40 000000000af10639
0x00000000090eeb90:   00000000074f1330 0000000000000001
0x00000000090eeba0:   ffffffff98dab088 0000000000000000
0x00000000090eebb0:   000000006bc911f0 000000000af1123a
0x00000000090eebc0:   000000000e41d950 0000000098dab040
0x00000000090eebd0:   0000000000000001 00000000074f1330
0x00000000090eebe0:   000000006af56480 0000000000000007
0x00000000090eebf0:   00000000090eee40 000000000af11696
0x00000000090eec00:   00000000074f1330 00000000074f1330
0x00000000090eec10:   00000000074f1330 0000000000000008
0x00000000090eec20:   0000000001bdb4b0 000000000af1178b
0x00000000090eec30:   0000000098dab040 ffffffffffffffc0
0x00000000090eec40:   0000000000000000 00000000074f1330
0x00000000090eec50:   00000000090eee40 000000000af11815
Instructions: (pc=0x000000000af087f4)
0x000000000af087e4:   21 00 48 03 d0 ff e2 48 85 f6 0f 84 4c 01 00 00
0x000000000af087f4:   8b 06 89 43 04 e9 4f 01 00 00 48 85 f6 0f 84 39
Stack: [0x0000000008cf0000,0x00000000090f0000),  sp=0x00000000090eeb60,  free space=4090k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
[error occurred during error reporting, step 120, id 0xc0000005]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j  CGTechIpcWrapper.askEngine2([Ljava/lang/Object;)[Ljava/lang/Object;+0
j  CGTechIpcWrapper.askEngine([Ljava/lang/Object;)[Ljava/lang/Object;+11
j  CGTechIpcWrapper.requestList(Ljava/lang/String;[Ljava/lang/String;LCGTechIpcList;)V+55
j  CGTechCutAdReport.refresh()V+292
j  CGTechCutAdReport.<init>(LCGTechGuiProduct;)V+376
j  CGTechCutAdReport.create(LCGTechGuiProduct;)V+18
j  CGTechCutAdCompare.actionPerformed(Ljava/awt/event/ActionEvent;)V+755
j  javax.swing.AbstractButton.fireActionPerformed(Ljava/awt/event/ActionEvent;)V+84
j  javax.swing.AbstractButton$Handler.actionPerformed(Ljava/awt/event/ActionEvent;)V+5
j  javax.swing.DefaultButtonModel.fireActionPerformed(Ljava/awt/event/ActionEvent;)V+35
j  javax.swing.DefaultButtonModel.setPressed(Z)V+117
j  javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Ljava/awt/event/MouseEvent;)V+35
j  java.awt.Component.processMouseEvent(Ljava/awt/event/MouseEvent;)V+64
j  javax.swing.JComponent.processMouseEvent(Ljava/awt/event/MouseEvent;)V+23
j  java.awt.Component.processEvent(Ljava/awt/AWTEvent;)V+81
j  java.awt.Container.processEvent(Ljava/awt/AWTEvent;)V+18
j  java.awt.Component.dispatchEventImpl(Ljava/awt/AWTEvent;)V+477
j  java.awt.Container.dispatchEventImpl(Ljava/awt/AWTEvent;)V+42
v  ~C2IAdapter
J  java.awt.LightweightDispatcher.retargetMouseEvent(Ljava/awt/Component;ILjava/awt/event/MouseEvent;)V
v  ~I2CAdapter
j  java.awt.LightweightDispatcher.processMouseEvent(Ljava/awt/event/MouseEvent;)Z+139
j  java.awt.LightweightDispatcher.dispatchEvent(Ljava/awt/AWTEvent;)Z+50
j  java.awt.Container.dispatchEventImpl(Ljava/awt/AWTEvent;)V+12
j  java.awt.Window.dispatchEventImpl(Ljava/awt/AWTEvent;)V+19
v  ~C2IAdapter
J  java.awt.EventQueue.dispatchEvent(Ljava/awt/AWTEvent;)V
J  java.awt.EventDispatchThread.pumpEventsForHierarchy(ILjava/awt/Conditional;Ljava/awt/Component;)V
v  ~OSRAdapter
j  java.awt.EventDispatchThread.pumpEvents(ILjava/awt/Conditional;)V+4
j  java.awt.EventDispatchThread.pumpEvents(Ljava/awt/Conditional;)V+3
j  java.awt.EventDispatchThread.run()V+9
v  ~StubRoutines::call_stub
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
  0x0000000001bdc220 JavaThread "Image Fetcher 0" daemon [_thread_blocked, id=1808]
  0x0000000001bd9c80 JavaThread "DestroyJavaVM" [_thread_blocked, id=2352]
  0x0000000001bdca30 JavaThread "CGTech3dx" daemon [_thread_in_native, id=996]
  0x0000000001bdbf70 JavaThread "VERICUT_1" daemon [_thread_blocked, id=2552]
  0x0000000001bdc4d0 JavaThread "VERICUT_0" daemon [_thread_blocked, id=2480]
  0x0000000001bdbcc0 JavaThread "TimerQueue" daemon [_thread_blocked, id=392]
=>0x0000000001bdb4b0 JavaThread "AWT-EventQueue-0" [_thread_in_native, id=2164]
  0x0000000001bdaf50 JavaThread "AWT-Windows" daemon [_thread_in_native, id=324]
  0x0000000001bdaca0 JavaThread "AWT-Shutdown" [_thread_blocked, id=3064]
  0x0000000001bda9f0 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=2784]
  0x0000000001bda740 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=1752]
  0x0000000001c53060 JavaThread "CompilerThread1" daemon [_thread_blocked, id=1448]
  0x0000000001c52d90 JavaThread "CompilerThread0" daemon [_thread_blocked, id=2712]
  0x0000000001c52ac0 JavaThread "AdapterThread" daemon [_thread_blocked, id=2028]
  0x0000000001bda490 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=1200]
  0x0000000001bda1e0 JavaThread "Finalizer" daemon [_thread_blocked, id=2356]
  0x0000000001bd9f30 JavaThread "Reference Handler" daemon [_thread_blocked, id=1828]
Other Threads:
  0x0000000001bc5da0 VMThread [id=2108]
  0x0000000001bc5ec0 WatcherThread [id=732]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
PSYoungGen      total 19008K, used 8562K [0x0000000057cc0000, 0x00000000590e0000, 0x0000000059210000)
  eden space 17664K, 43% used [0x0000000057cc0000,0x00000000584349c8,0x0000000058e00000)
  from space 1344K, 69% used [0x0000000058e00000,0x0000000058ee8000,0x0000000058f50000)
  to   space 1408K, 0% used [0x0000000058f80000,0x0000000058f80000,0x00000000590e0000)
PSOldGen        total 43712K, used 34364K [0x0000000055210000, 0x0000000057cc0000, 0x0000000057cc0000)
  object space 43712K, 78% used [0x0000000055210000,0x000000005739f398,0x0000000057cc0000)
PSPermGen       total 21248K, used 18410K [0x0000000050010000, 0x00000000514d0000, 0x0000000055210000)
  object space 21248K, 86% used [0x0000000050010000,0x000000005120aa90,0x00000000514d0000)
Dynamic libraries:
0x0000000000400000 - 0x0000000000411000     C:\PROGRA~1\cgtech603\windows64\jre\bin\javaw.exe
0x0000000078ec0000 - 0x0000000078ff9000     C:\WINDOWS\system32\ntdll.dll
0x0000000077d40000 - 0x0000000077eb3000     C:\WINDOWS\system32\kernel32.dll
0x000007ff7fee0000 - 0x000007ff7ffe5000     C:\WINDOWS\system32\ADVAPI32.dll
0x000007ff7fd30000 - 0x000007ff7fed9000     C:\WINDOWS\system32\RPCRT4.dll
0x0000000078c30000 - 0x0000000078d3c000     C:\WINDOWS\system32\USER32.dll
0x000007ff7fc90000 - 0x000007ff7fd29000     C:\WINDOWS\system32\GDI32.dll
0x000007ff7fc00000 - 0x000007ff7fc86000     C:\WINDOWS\system32\MSVCRT.dll
0x0000000008000000 - 0x00000000084ef000     C:\PROGRA~1\cgtech603\windows64\jre\bin\server\jvm.dll
0x000007ff7e060000 - 0x000007ff7e0b0000     C:\WINDOWS\system32\WINMM.dll
0x0000000010000000 - 0x0000000010009000     C:\PROGRA~1\cgtech603\windows64\jre\bin\hpi.dll
0x000007ff7e1b0000 - 0x000007ff7e1c0000     C:\WINDOWS\system32\PSAPI.DLL
0x0000000001dc0000 - 0x0000000001dd0000     C:\PROGRA~1\cgtech603\windows64\jre\bin\verify.dll
0x0000000001dd0000 - 0x0000000001dfa000     C:\PROGRA~1\cgtech603\windows64\jre\bin\java.dll
0x0000000001e00000 - 0x0000000001e14000     C:\PROGRA~1\cgtech603\windows64\jre\bin\zip.dll
0x00000000060c0000 - 0x00000000062b7000     C:\Program Files\cgtech603\windows64\jre\bin\awt.dll
0x000007ff78d50000 - 0x000007ff78d91000     C:\WINDOWS\system32\WINSPOOL.DRV
0x000007ff7d320000 - 0x000007ff7d359000     C:\WINDOWS\system32\IMM32.dll
0x000007ff7ece0000 - 0x000007ff7ef52000     C:\WINDOWS\system32\ole32.dll
0x0000000006460000 - 0x00000000064bc000     C:\Program Files\cgtech603\windows64\jre\bin\fontmanager.dll
0x00000000070c0000 - 0x00000000071fd000     C:\WINDOWS\system32\nview64.dll
0x000007ff7ef60000 - 0x000007ff7effb000     C:\WINDOWS\system32\SHLWAPI.dll
0x000007ff7f190000 - 0x000007ff7fb98000     C:\WINDOWS\system32\SHELL32.dll
0x000007ff7e9f0000 - 0x000007ff7eb04000     C:\WINDOWS\system32\OLEAUT32.dll
0x000007ff76200000 - 0x000007ff762ee000     C:\WINDOWS\WinSxS\amd64_Microsoft.Windows.Common-Controls_6595b64144ccf1df_5.82.3790.2778_x-ww_7B85EF6C\COMCTL32.dll
0x000007ff7fbf0000 - 0x000007ff7fbfb000     C:\WINDOWS\system32\VERSION.dll
0x000007ff7f000000 - 0x000007ff7f187000     C:\WINDOWS\WinSxS\amd64_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.3790.2778_x-ww_DAFA34F1\comctl32.dll
0x000007ff7e2f0000 - 0x000007ff7e32c000     C:\WINDOWS\system32\NTMARTA.DLL
0x000007ff76f80000 - 0x000007ff76f96000     C:\WINDOWS\system32\SAMLIB.dll
0x000007ff7e780000 - 0x000007ff7e7e6000     C:\WINDOWS\system32\WLDAP32.dll
0x00000000073e0000 - 0x000000000742c000     C:\WINDOWS\system32\NVWRSDE.DLL
0x000007ff7a240000 - 0x000007ff7a2df000     C:\WINDOWS\system32\MSCTF.dll
0x0000000007480000 - 0x0000000007494000     C:\Program Files\Logitech\SetPoint\lgscroll.dll
0x0000000078130000 - 0x00000000781ff000     C:\WINDOWS\WinSxS\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_3FEA50AD\MSVCR80.dll
0x000000007c420000 - 0x000000007c531000     C:\WINDOWS\WinSxS\amd64_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_3FEA50AD\MSVCP80.dll
0x00000000075e0000 - 0x00000000075fa000     C:\Program Files\cgtech603\windows64\jre\bin\net.dll
0x000007ff77150000 - 0x000007ff77180000     C:\WINDOWS\system32\WS2_32.dll
0x000007ff77140000 - 0x000007ff7714c000     C:\WINDOWS\system32\WS2HELP.dll
0x0000000007680000 - 0x000000000768a000     C:\Program Files\cgtech603\windows64\jre\bin\nio.dll
0x0000000007a90000 - 0x0000000007ac1000     C:\Program Files\cgtech603\windows64\jre\bin\jpeg.dll
0x0000000007af0000 - 0x0000000007af7000     C:\Program Files\cgtech603\windows64\jre\bin\jawt.dll
0x000007ff63940000 - 0x000007ff63a78000     C:\WINDOWS\system32\opengl32.dll
0x000007ff6d5f0000 - 0x000007ff6d626000     C:\WINDOWS\system32\GLU32.dll
0x000007ff79190000 - 0x000007ff79202000     C:\WINDOWS\system32\DDRAW.dll
0x000007ff793e0000 - 0x000007ff793e8000     C:\WINDOWS\system32\DCIMAN32.dll
0x0000000007b80000 - 0x0000000007b99000     C:\WINDOWS\system32\nvwddi64.dll
0x000000000acf0000 - 0x000000000b756000     C:\Program Files\cgtech603\windows64\vericut\CGTech.dll
0x000007ff770f0000 - 0x000007ff770fa000     C:\WINDOWS\system32\WSOCK32.dll
0x000007ff79350000 - 0x000007ff79374000     C:\WINDOWS\system32\AVIFIL32.dll
0x000007ff7fbc0000 - 0x000007ff7fbe0000     C:\WINDOWS\system32\MSACM32.dll
0x000007ff793f0000 - 0x000007ff7941e000     C:\WINDOWS\system32\MSVFW32.dll
0x000007ff7d360000 - 0x000007ff7d3d7000     C:\WINDOWS\system32\comdlg32.dll
0x000007ff77370000 - 0x000007ff77408000     C:\WINDOWS\system32\NETAPI32.dll
0x0000000007be0000 - 0x0000000007c0c000     C:\Program Files\cgtech603\windows64\jre\bin\dcpr.dll
0x000007ff76fe0000 - 0x000007ff7705c000     C:\WINDOWS\system32\mswsock.dll
0x000007ff6d1f0000 - 0x000007ff6d281000     C:\WINDOWS\system32\hnetcfg.dll
0x000007ff76fa0000 - 0x000007ff76fab000     C:\WINDOWS\System32\wshtcpip.dll
0x000007ff7e8f0000 - 0x000007ff7e93e000     C:\WINDOWS\system32\DNSAPI.dll
0x000007ff7e820000 - 0x000007ff7e82b000     C:\WINDOWS\System32\winrnr.dll
0x0000000007d90000 - 0x0000000007d97000     C:\WINDOWS\system32\rasadhlp.dll
0x000007ff7e7f0000 - 0x000007ff7e812000     C:\WINDOWS\system32\Secur32.dll
0x0000000069500000 - 0x0000000069c75000     C:\WINDOWS\system32\nvoglnt.dll
0x000000000f230000 - 0x000000000f252000     C:\WINDOWS\system32\siappdll.dll
0x000000000f260000 - 0x000000000f272000     C:\WINDOWS\system32\SPWINI.dll
0x000007ff77110000 - 0x000007ff77131000     C:\WINDOWS\system32\MPR.dll
0x000007ff7ccc0000 - 0x000007ff7ccca000     C:\WINDOWS\System32\drprov.dll
0x000007ff649b0000 - 0x000007ff649c6000     C:\WINDOWS\System32\ntlanman.dll
0x000007ff65140000 - 0x000007ff65164000     C:\WINDOWS\System32\NETUI0.dll
0x000007ff650e0000 - 0x000007ff65138000     C:\WINDOWS\System32\NETUI1.dll
0x000007ff7ccd0000 - 0x000007ff7ccdd000     C:\WINDOWS\System32\davclnt.dll
0x000007ff7d8e0000 - 0x000007ff7da57000     C:\WINDOWS\system32\SETUPAPI.dll
0x000007ff7cc70000 - 0x000007ff7ccb1000     C:\WINDOWS\system32\apphelp.dll
0x0000000009810000 - 0x00000000098ed000     C:\WINDOWS\system32\CLBCatQ.DLL
0x0000000077c40000 - 0x0000000077d06000     C:\WINDOWS\system32\COMRes.dll
0x000007ff7df70000 - 0x000007ff7df7c000     C:\WINDOWS\system32\LINKINFO.dll
0x000007ff7dda0000 - 0x000007ff7ddd1000     C:\WINDOWS\system32\ntshrui.dll
0x000007ff7c4a0000 - 0x000007ff7c5a9000     C:\WINDOWS\system32\USERENV.dll
VM Arguments:
jvm_args: -Dsun.java2d.noddraw=true -Xms16m -Xmx64m -Xss4m
java_command: Vericut dynamic usr=L:\auftraege_2006\20061257_Fertigteil_Alpha_1b\Zwischenablage\drabke_37306194.usr
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\PROGRA~1\cgtech603\windows64\vericut;C:\PROGRA~1\cgtech603\windows64\license;C:\PROGRA~1\cgtech603\windows64\spatial\acisR15\bin\NT_DLL;C:\PROGRA~1\cgtech603\windows64\spatial\iopR15\bin\NT_DLL;C:\PROGRA~1\cgtech603\windows64\spatial\iopR15\lib3dx\intel_a\code\bin;C:\Program Files (x86)\Tcl\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files (x86)\UGS\NX 3.0\UGII\;C:\Program Files\proeWildfire 3.0\bin
USERNAME=drabke
OS=Windows_NT
PROCESSOR_IDENTIFIER=EM64T Family 15 Model 4 Stepping 10, GenuineIntel
---------------  S Y S T E M  ---------------
OS: Windows Server 2003 family Build 3790 Service Pack 1
CPU:total 2 em64t ht
Memory: 4k page, physical 4193580k(1998896k free), swap 10900024k(8857684k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (1.5.0_06-b05) for windows-amd64, built on Nov 10 2005 10:42:23 by "java_re" with unknown MS VC++:1400
