Hello,
My Fanuc 15MA with Macro B capability seems to have a difference of opinion with Vericut V5.4.5 and V6.0.1, and I am wondering if anyone else has seen this.
BACKGROUND:
AND is defined by Fanuc as "Logical product (at every bit of 32 bits)".
On the Fanuc, for example, [3AND3] = 3. I am not electrical, but I am told that this is the result of some BCD math wizardry.
PROBLEM:
In Vericut, the answer is not the same. In Vericut, [3AND3] = 1. Oops.
SUMMARY:
This makes a big difference to me because I am looking at the Vericut probing module, and I am using standard subroutines provided by the probe manufacturer. Their standard routines use AND. The simulation was not returning the correct values in certain key registers. I discovered that I must make edits to their subroutines on my PC to make them work for my programs in Vericut. I do not really feel great about doing this. I would be willing to bet that OR and XOR misbehave as well.
CONCLUSION:
So I am wondering if anyone has encountered this and what you did about this.
Thank You
In the the Control File menu: Configuration -> Word Format
change:
Name Type Sub_Type ...
AND Logical AND
OR Logical OR
to:
NAME Type Sub_Type ...
AND Logical Bitwise_AND
OR Logical Bitwise_OR
XOR Logical Bitwise_XOR
Just watch out for operator precedence issues.
Jerry Millett
Thank You. That worked in V6. I had to edit my .ctl file, because none of the V6 library fanuc files had the "Logical_Bitwise" definitions within.
I did not totally understand your caveat "Just watch out for operator precedence issues." I decided to do more testing. Oh, shucks! I ended up with conflicting results. I created a simple test script and ran it three ways:
1. Fanuc control
2. Vericut with legacy AND
3. Vericut with Bitwise AND
All three ways give me different results. Here is my test script:
#551=[3AND3EQ1]
#552=[[3AND3]EQ1]
#553=[3AND8NE8]
#554=[[3AND8]NE8]
I hoped that Fanuc and Bitwise AND would agree. Wrong! Here are the results:
Register Fanuc Bitwise AND Legacy AND
#551 0 0 0
#552 0 0 1
#553 1 0 0
#554 1 1 1
===========================================I can't see a way out of this one. I'll have to edit the vendor's sub-routines and submit a trouble ticket.
Thanks Again.
