#1 2006-09-25 10:32:11
Roger Bombassei
Cut Stock Causes Vericut 6 to Shut Down
I'm having a problem trying to use cut stock from a previous operation.  When I try to run my program (Gcode), I get thrown out of Veriut.  It happens on the first block when I use single block.  And it happens in Machine veiw or workpiece veiw.  I tried turning off machine sim and collision detection and it still happens.
If I remove the stock, the program will run all the way thru.
Anybody see this problem before?
#2 2006-09-26 12:25:45
Roger Bombassei
Re: Cut Stock Causes Vericut 6 to Shut Down
I talked to tech support and was told the problem I was having was caused by creating seperate Project files for each position.
I followed the instructions from Training sessions 22, 23, & 24 and now it is working.  Now I have 2 Setups in one Project file.  I will have 6 Setups and several machines in this Project.  :?
