Downloading and Installing a VERICUT point release for Windows from the CGTech FTP site
VERICUT for Windows is available on the CGTech FTP site. The following steps will guide you through downloading and installing a VERICUT point release (we’ll use 6.0.2 as an example below):
1. Visit http://www.cgtech.com/update/ and complete the "Request VERICUT 6.0 Software Update" on-line form. Make sure that you select "Password for the zip file on FTP site." A password for the password-protected Zip file on the CGTech FTP site will be emailed to you within 24 hours.
2. Download ftp://ftp.cgtech.com/Download/pointrel/windows/602.zip (the zip file name will be different for each point release) from the CGTECH FTP site. The file contains the Windows installer files (same files found on the VERICUT 6.0.2 CD).
3. Unzip these files to a folder on a local drive.
4. Run the file, install.exe, to start the installation process. From here on, the installation is the same as if you were installing from the VERICUT 6.0.2 CD. For additional information about the VERICUT installation process, please refer to the VERICUT Installation Guide, install.pdf, included in the Zip File.
