History:
The BAT file that is referenced by the menu ?Update licenses on running server? does what it should do, it updates the licenses on the server. But instead of updating them on the running server, it removes the service, installs it and restarts the server. The server then has the new license information.
Problem:
The problem comes if the person updating the license in the server does not have Administrator privileges, he will not be able to remove and install the service and therefore the license will not be updated.
Solution:
Change the menu to point to the correct executable (update_license.bat)
Start > All Programs > CGTech VERICUT 6.0 > License Server Only > Update licenses on running server.
Right-click on ?Update licenses on running server?, Properties , Target = C:\cgtech60\windows\license\update_license.bat
