#1 2006-06-06 23:46:07
Problem: Unix - Cutter Grinder - Mold & Die I/F
Problem:
Cutter Grinder and Mold & Die do not start up correctly on UNIX using the "standard" parts
Solution:
Change the name of the startup file to remove Upper case in the extension (.VcProject)
Cutter Grinder:              Change grinder_interface.VcProject to grinder_interface.vcproject
Mold & Die :                  Change mold_die_inch.VcProject to mold_die_inch.vcproject
                                                            mold_die_mm.VcProject to mold_die_mm.vcproject
