#1 2006-06-06 23:38:12
Problem: mounting CDROM on HP-UX
Problem:
VERICUT only partially installs on HPUX. The install log shows errors.
Solution:
VERICUT’s CD installation on HPUX requires the CD to be mounted with Rockridge extensions.  Use the following commands to mount the VERICUT CD:
1) Make sure the directory containing the PFS utilities (/usr/sbin) is in your execution PATH.
2) Edit (or create) the /etc/pfs_fstab file to contain a line like this:
     <device> <mount_dir> pfs-rrip xlat=rrip 0 0
   Where:
     <device> is the path to your CD-ROM reader (e.g. /dev/dsk/c1t2d0)
     <mount_dir> is the path to an *existing* directory where the CD-ROM will be mounted (e.g. /rr_cdrom)
3) Type the following in a command shell:
     # nohup pfs_mountd &
     # nohup pfsd 4 &
   Note: To permanently enable Rockridge these daemons can be started from an rc script.
4) Mount the drive with the command:
      pfs_mount  <device> | <mount_dir>
You can now continue with the VERICUT installation. When you are finished with the install you can unmount the CD with:
      pfs_umount <device> | <mount_dir>
Additional information on mounting a CD with Rockridge extension on HPUX can be found at
http://www.faqs.org/faqs/hp/hpux-faq/section-87.html
