#1 2006-06-02 12:21:23
Tim Johnson
Error: Cannot locate subroutine 83 for call
I'm a vericut newby and am trying to run two seperate program files in a simulation for a pallet pool. The first file is is a "pallet preparation" program that uses variables specific to that pallet. When the program gets to the M98 portion to go to the next program file the alarm comes up and the program continues on to the end of the first file. The help page doesn't list this alarm. Is there something I can do to run both files?
Tim Johnson
CNC Programmer
LECO Corp.
VERICUT 7.0.3 (64)
#2 2006-06-08 03:23:29
TomB
Re: Error: Cannot locate subroutine 83 for call
Tim,
sounds like you need to add the actual subprogram being called to your subroutine list.
You can add a subroutine in the setup>g-code>settings area or under setup>control>advanced. If you place it in the advanced area it will not be displayed in the toolpath window when it is executed.
Hope this helps
Tom
#3 2006-06-12 21:17:18
Tim Johnson
Thanks Tom.
That worked well.
Tim
Tim Johnson
CNC Programmer
LECO Corp.
VERICUT 7.0.3 (64)
