Hi All
I have some problem in CATV Generation process on CATIA V5
(1). Incorrective Generated Model, Stock, etc When Reverse Axis
(Reverse Axis = Right Hand axis = used for Oppsite Part)
(2). Runtime Error When 'Model Placement' -> 'Selection Point' Click
Please Solution This
System Environments :
- Windwos XP Professional (Korean Version)
- CATIA V5R16SP2
- VERICUT 5.4.4 (V5.4.5 Tested -> Same Problem)
(Labrary Date : 04/19/05)
- Java Version 1.4.2
:End
1) VERICUT does not output the inversed model. VERICUT has no concept of a left hand coordinate system (standard being the right-hand rule). But in VERICUT 6.0, you will have the ability to reverse the STL model. Still it will be a manual operation in VERICUT once the models are transfered.
2) Possible reason:
Many CATIA site administrators use the old IBM method of installing once then copying the installation to other platforms. This fails in the windows environment since the registry entries are only created during an installation. This situation can cause the error.
Also, CATIA's installation program had a bug with R12, and I think also R13, where installing a parallel update (ie running both R11 and R12, or R12 and R13) broke the registry entries and cause the same error.
Fortunately, there is a utility program that fixes the registry entries. Run the following line (either from a command shell or the Run dialogue:
PROGRAM FILES\DASSAULT SYSTEMS\B13\INTEL_A\CODE\BIN\CNEXT.EXE /REGSERVER
The "B13" part depends on your CATIA version.
It was brought to my attention that a solution was found for the Model Placement problem with CATIA V5R16.
Please disregard the previous suggestion. Please contact your local Tech Support (support.ap@cgtech.com) to receive the latest executables.
Sorry about the confusion,
(1)
We run VERICUT V5.4.4 on Dual platform that
-IBM AIX with CATIA V4.2.4
-MS XP with CATIA V5R16
i could generated inversed model on CATIA V4 with VERICUT V5.4.4CATV Option Used
'AXES SYSTEM -> CURRENT' in 'CATV TRANSFER' Windows
(2) Cleared this problem from local supportthank you for timeless respons
