For example installing in Program Files will cause an error popup on computer start saying the license cannot be found, this is because of the space in the path used by LSERVOPTS
After setting the license file variable via:
Start, All Programs, CGTech VERICUT 5.4.5, License Administration, License Server Only, Set License File Variable
Edit via:
Control Panel, System, Advanced, Environment Variables, LSERVOPTS
Add "" around the path to the license file and any other paths such as if using a log file. Example below:
Original:
-s C:\Program Files\CGTech545\windows\license\cgtech.lf
Change to:
-s "C:\Program Files\CGTech545\windows\license\cgtech.lf"
