#1 2006-03-01 22:50:26
DaveF
TIP: A way to blank components without changing mch file
TIP: A way to change component visibility without changing mch file
I found programmers were saving machines only because they wanted to blank components. They have a valid reason because the components like base, and X, were in not in danger of ever colliding.
yikes
I got around the need to change the .mch file, by using sub-programs
I also needed to define words and have the words call the MACRO "SetComponentVisibility"
I gave each programmer a unique sub-programs by name
For example my file is called DAVE_F_PREFS (1st name_last initial)
The sub-programs looks like this
O0102
N1 VERICUT_BLANK_BASE
N2 VERICUT_BLANK_X
N3 VERICUT_BLANK_Z
N9 VERICUT_BLANK_SPECIAL_ATTACH_PLATES_LOWER
N10 VERICUT_BLANK_SPECIAL_ATTACH_PLATES_UPPER
N12 VERICUT_BLANK_MIRRORED_X_WAY_COVER
M99
they can edit, add delete components as they like
This is the regisers
    WORD_VALUE "VERICUT_BLANK_X" {
        MACRO "SetComponentVisibility" {
            OVERRIDE_VALUE 0 TEXT_OVERRIDE_VALUE "X"
    WORD_VALUE "VERICUT_BLANK_Y" {
            OVERRIDE_VALUE 0 TEXT_OVERRIDE_VALUE "Y"
    WORD_VALUE "VERICUT_BLANK_Z" {
            OVERRIDE_VALUE 0 TEXT_OVERRIDE_VALUE "Z"
    WORD_VALUE "VERICUT_BLANK_A" {
            OVERRIDE_VALUE 0 TEXT_OVERRIDE_VALUE "A"
    WORD_VALUE "VERICUT_BLANK_B" {
            OVERRIDE_VALUE 0 TEXT_OVERRIDE_VALUE "B"
    WORD_VALUE "VERICUT_BLANK_BASE" {
            OVERRIDE_VALUE 0 TEXT_OVERRIDE_VALUE "BASE"
    WORD_VALUE "VERICUT_BLANK_MIRRORED_X_WAY_COVER" {
            OVERRIDE_VALUE 0 TEXT_OVERRIDE_VALUE "MIRRORED_X_WAY_COVER"
    WORD_VALUE "VERICUT_BLANK_HEAD_CHANGER_TABLE" {
            OVERRIDE_VALUE 0 TEXT_OVERRIDE_VALUE "HEAD_HOLDER_TABLE"
Yes, I could have also used CGTECH_MACRO
:oops:
But I am a control rookie, (2005) and wanted to walk before I run, and also try different things.
:twisted:
#2 2006-03-09 16:07:06
tri
Re: TIP: A way to blank components without changing mch file
hey dave,
there's a better way which you don't need to define all the macro::
such as ::: Vericut_blank_x, Vericut_blank_base, and so on...
Define one macro named
Vericut_bank   typed: macro     alpha-numeric
In word address
WORD_VALUE "Vericut_blank" {
OVERRIDE_VALUE 0
you can blank any component in the .mch file by
Vericut_blank x
Vericut_blank y
Vericut_blank base
and so on..........
So, what do you think?
#3 2006-03-10 19:05:18
DaveF
That sounds good.
I will give it a shot the next time I need to dink with the machine.
smile
dave
ps.
speaking of Mass., I have a cousin with a house, right on the bay, in provinectown.
That made for a lot of fun growing up.
Yes, I'm from New Jersey, and I used to work in a chemical plant
