#1 2006-02-18 15:56:08
Armageddon1801
Where can we change lokal position variables
Another question,
the lokal position variables are
#5001 = X-Axis / #5021 and so on
#5002 = Y-Axis / #5022
#5003 = Z-Axis / #5023
How can we change it to
#5002 = Z-Axis / #5022
#5004 = Y-Axis / #5023
or some other constelation?
#2 2006-02-21 17:50:47
Re: Where can we change lokal position variables
Go to Setup > Adv. Option; Event tab
Look for the macro SetDynamicVars with the Override text:
AxisLocalPlus 0000000 5001 5002 5003 5004 5005 5006 5007 5008 5009
edit the override text to assigne the values as needed. The order is XYZABCUVW
so you might have something like:
AxisLocalPlus 0000000 5001 5004 5002...
To get more information on the configuration, select the macro name and press F1.
#3 2006-02-21 18:22:17
Armageddon1801
Thats easy. *lol* should open my eyes. *g*
Seems in the samples are wrong settings.
If i load a fanuc lathe demo and look at the variables screen on local-x then this data is in radius value. When i type in MDI:
T0101
G0 X50.0
The tool goes to this position but in the variables display on local-x it is 25.0
If i show the info screen and switch workpiece coordinates on there is the same value. X25.0
Wrong settings or bug? Or i am mad.  :?
#4 2006-02-21 18:58:34
The program is in diameter mode, the X50 represents a diameter of 50, therefore the local tool position relative the NC program origin is 25.
It is not a bug, it is how the control is configured. Now, the question is: Is it how your real control behaves?
When you have X50, what is the value of #5001? 50 or 25?
#5 2006-02-21 19:17:28
Armageddon1801
On the real Control #5001 is 50 on a diameter of X50.0
#5021 and #5041 are also in diameter mode
#6 2006-02-21 21:56:31
In the Events:
under End of Block Processing
Add/Modify
Select-- Variable
Variable Number = 5001
Override Value = 2 * #5001   (spaces between the expressions)
Add
--repeat for #5021, #5041
#7 2006-02-22 09:38:23
Armageddon1801
Thanks that works fine.
But on the status window the position of the tool is always an diameter value. :?
#8 2006-02-22 20:03:36
jsmillett
What I have done is let SetDynamicVars set variables 50?0 to the X radius values then have End of Block Processing set variables 50?1 to the diameter values of twice the radius values.  Also, in the user file under Setup -> G-Code -> Variables, I define 50?0 as the Radius X values and 50?1 as the Diameter X values.   In this way, any references to the 50?1 variables get the desired Diameter values.
EVENTS {
TYPE CONVERSION_INIT {
  MACRO "SetDynamicVars" { TEXT_OVERRIDE_VALUE "AxisLocalPlus 0000000 5000 ... }
  MACRO "SetDynamicVars" { TEXT_OVERRIDE_VALUE "AxisMachineMinus 0000000 5020 ... }
TYPE BLOCK_FINISH {
  MACRO "BlockFinish"
  VARIABLE "5001" { OVERRIDE_EXP "2 * #5000" }
  VARIABLE "5021" { OVERRIDE_EXP "2 * #5020" }
Jerry Millett
