#1 2006-02-16 20:28:55
Armageddon1801
IF THEN - statement on FANUC-16i/18i...
Hi everybody,
i have one question about the simluation of macroprogramms inside VeriCut.
The following Code works in the Machine but in VeriCut comes alarm.
IF[#10EQ#0]THEN IF[#23NE#0]THEN #3000=0(TESTALARM)
looks like the second IF THEN - statement dont work in VeriCut.
But why?
Thanks for answers
#2 2006-02-17 20:50:39
Re: IF THEN - statement on FANUC-16i/18i...
Turn in Enhancement Requests.  big_smile
Vericut does not simulate every condition in the Macro B language.  Neither does it do all the Macro B syntax checks.
Use of [] or non use of [] has little effect in IF statements unless precedence is involved.  You can even mismatch them and there is no error.
THEN is not  defined only GOTO is.  THEN  is a default action.  You can leave it off and it acts as if it is there in most cases.  It wont work at the machine.
#3 2006-02-17 23:01:08
Control > Adv. Options ; Events tab
Start of Processing
Add the macro:  IfCheckAllMacros With an override value of 1, it causes the IfCheck macro to be applied to all macros called after the IfCheck on the current block.
I did some short tests and it seemed to work.
#4 2006-02-18 15:50:05
Armageddon1801
I will try it. Thanks.
