#1 2024-02-27 15:00:59
MWeers
Vericut 9.4.1 Multiple VcReview files from batch?
In the past I made a batch file to create a VcReview file after executing the simulation.
For this I used the parameter "save_vcreview=<file>"  which works fine.
Recently we have upgraded to Vericut 9.4.1 and like the creation of multi VcReview files a lot.
Unfortunately the mentioned parameter overwrites the setting to create multiple files, only the file named <file> is created.
Question:
What parameter should I use with the batch file when multiple VcReview files (at the end of each setup) are requested?
Maarten Weers
VDL ETG Almelo
The Netherlands
#2 2024-02-29 06:31:31
MWeers
Re: Vericut 9.4.1 Multiple VcReview files from batch?
I noticed I didn't include a path to the VcReview file name. Therefor the files where made in the working directory instead the location I was monitoring.
Include the full path with the file name and everything works fine.
Maarten Weers
VDL ETG Almelo
The Netherlands
