#1 2022-08-30 11:41:13
MovayedN
Driven Point from the center of the ball
We have programmed from the center of the Lollipop Cutter Ø25 (all ISO code from the center of the mill)
We have defined Tool in Tool list from center (Spherical End Mill), but it is not correct yet.
We have put many Macros under T
_ DrivenPointOffsetDirect
_ GageOffsetDirect2
_ DynamicToolTipOnOff
_ DynamicToolTipAdjust
What I have missing to run the Tool to the center of the ball?
Thanks for the help
#2 2022-09-05 09:36:32
MovayedN
Re: Driven Point from the center of the ball
The feature of Dynamic Tool Tip applies to only turning tools.
Macro DynamicToolTipOnOff it is perfect, but it is only for turning.
When I use RtcpUses
Value 2
Tool took more from one side (Forward)
When I use
Value 3
Took from the other side (Back)
Is there anyone who has any idea?
#3 2022-09-12 07:48:56
For tool length offsets you normally only need TurnOnOffGageOffset, often G43.x or similar takes care of the rest.
#4 2022-09-13 05:21:47
MovayedN
Thanks for reply Tony
We have control with Tool length offset, but it is a special programming method, therefore we need such as turning with B axis from the center of the insert macro.
M06 T01
G43 H1 D1
I have under G43
TurnOnOffGageOffset
Value 1
IMMEDIATE
Does not care about different points in the surfaces of the ball,
therfor Tool took more material from one side of pocket.
Driven point it starts perfect in center of ball, but when moving, driven point follows center of ball only to Z axis, not C,and B axis.
#5 2022-09-13 07:16:25
What make/model is the machine?
#6 2022-09-13 10:10:21
MovayedN
CG Tech has no machine like it in the library.
If I get your email, I can send more information.
#7 2022-09-14 11:37:13
I have forwarded the information to support in the UK, they will be touch shortly
