#1 2022-02-03 20:44:54
SSpires
Macro record and Playback
We have lots of different machines in the shop and we are now required to run vericut every time the shop decides to run it on a different machine.  Catia And NX both have a function that allows to record what your doing and save it to playback later.  Something like this would be useful when switching machines.  One could record changing the control and the machine and all the other items that need to be set and just call or add the macro to the tool bar.  Which would be just a simple click on each setup to change the setting enstead of opening each setup and changing everything just to have to do it multiple times for all the positions.  For example we could have a macro called Cincinnati V30 and buy running it it could change out both the control and machine and load a sub program and the correct tool list for that machine in the active setup.
#2 2022-02-09 16:11:10
Re: Macro record and Playback
Something similar to this was considered, but nothing has been implemented as of yet.
