Vericut Time Vs. Machine Time:: DMC 60T
Cycle time from Vericut is off from what the operator records from machine.
What do I need to do in order for Vericut to generates the right time?
Rapid feedrate of the axes is set to machine information.
I noticed that ToolChain also plays part in cycle time.
I had this job run in Vericut, and before I add in ToolChain::
The time come out from Vericut to be 83mins.
The actual machined time is 90mins.
But when I added in ToolChain::
Vericut = 138mins
Does anyone know the solution to this??
If you added some axis motions to your tool chain assembly (like in vericut.usr) it might be that the cycle time is considered in the calculation. if you have such motions, add the macro ProcessTimeOnOff before and after the motions in your control.
also verify that the tool change parameters in the Tool Chain component attributes are set correctly.
To test the tool change time:
Open Info> Status
MDI: T1 M06
-- notice the difference in time.
I do have the ProcessTimeOnOff macro in my control.
Toolchange parameters might not be set correctly ::
Tool exchange time is set @ 5sec.
This is the website where i got my tool change parameter:
http://www.gildemeister.com/us,milling, … ument&ma=2
Likely, it didn't tell me much.
Vericut = 138mins
Let just say: if I dont' have toolchain and run this two jobs::
Job #1: machine time = 90mins
vericut time = 83mins
Job #2: machine time = 30mins
vericut time = 20mins
And now I added in the toolchain and rerun that two jobs::
Job #1: vericut time = 138mins
Job #2: vericut time = 32mins
:? :? :? I'm really confusing!!!
There is another one... I ran this job #3 on vericut and get 18mins.
But it's not fast enough. So, I went back and speed up the feedrate, and rpm.
Then I reran it through vericut and got 19mins.
How is that posible???
