#1 2020-03-31 23:13:46
RPervier
NXV Interface Setup Issues
Hello All,
I am currently running into some issues trying to setup the NXV Interface. Every time that I try to launch the nx12.bat file, the cmd prompt appears for a split second and then disappears and nothing happens. I went through step-by-step and added each environment variable, reset my workstation, and still nothing. What is really confusing me is that on my prior workstation all I did was run the nx12.bat file and everything worked perfectly fine, I didn't even have to define any environment variables.
I have uninstalled and reinstalled Vericut 9.0 twice now to double check if that was the issue but it wasn't. Could there be a fault in the NX installation that is causing this? Before I go through the lengthy process of uninstalling NX and CPD, I would like to see if anyone has any other suggestions?
Another concern, a colleague of mine has setup the NXV interface on his workstation and it is working. He sent me his nx12.bat file from his hardrive. I compared the nx12.bat file on my hardrive to the one he sent me inside the Cimco Edit File Compare and they are very different.
#2 2020-04-14 06:47:26
Re: NXV Interface Setup Issues
It doesn't sound like your NX installation is incorrect.
All that the NX12.bat file does is set a bunch of variables for Vericut (CGTECH_etc...) and start NX12 like it is done by the siemens batch file.
Could it be that you have multiple NX installations? This might cause that env variable UGII_BASE_DIR has the wrong value.
You can try to hard code this in the NX12.bat file by adding the following line after SetLocal:
set UGII_BASE_DIR="C:\Program Files\Siemens\NX 12.0"
