Hello all,
In command TCOFR I need to change output values which has been written to $P_TCANG variables.
I need to swapped the solution (solution 2 becomes solution 1, solution 1 becomes solution 2)
It should be done by variable _SOL2, but I can´t find this variable and dont know where to change it.
Can anyone advice me?
Martin
The _SOL2 variable is defined in the CYCLE800-call and is later set to ==1 if a number of conditions are met.
BR,
Svante
Svante Eriksson
System owner
