Whenever I open Vericut, the Status panel displays all of the default groups and selections within each group. Any changes I made in a previous session are lost.
This has been going on for quite some time, I just got aggravated enough today to finally post the issue. Any help would be appreciated! (Currently running v8.2.1)
The Status settings are saved with the vcproject. If you are using a CAM interface, open the template you are using, change the Status fields that are useful to you, then save the vcproject. Next time you use that file, the settings should be there.
I put a request in when I was at VUE to have this and the HUD settings to be saved with the user settings as each person may want to see different things, i.e. as a developer I want to see more than a programmer would.
