I installed Vericut 8.2 license server on our license server.
I install the software on my PC (Windows 10) - it opens up fine.
I tried to install Vericut 8.2 on some other machines (both Windows 7 & Windows 10)
(including running the install as "run as administrator")
Install to the standard install folder.
On all other machines, when I run Vericut, I get the "splash" screen, then a Java error:
"Java(TM) Platform SE Binary has stopped working"
I have contacted tech support ( Case#100457-00651200), but they seem unable to shed any light.
I know we have a gazillion scanners/checkers/etc. to defend against the "nasties" out there, so I don't know if that is the issue (but I would assume they would treat my PC the same as all the others).
Any ideas?
Is there a Java log somewhere I could look at to see what the error is?
Ken Akerboom
Moog, Inc.
Isn't there a log created in %temp% or the folder from witch Vericut was started.
It's time that the whole world stops with this annoying java.
95% of all problem I experience with various software apps are java related.
By the time software developers have cleared all issues, java updates introduces new ones. The arrogance of Oracle seems limitless.
I checked - no log file is being created.
On systems that it does run on, the log file is created as you indicate.
Ken Akerboom
Moog, Inc.
