#1 2018-05-02 22:56:17
epoirier
Parsing program message strings
Hello all,
I'm having trouble with something that should be easy, hoping someone has a solution.
Our post outputs tool messages that look like this: (T217 CEM). I want to parse the "217" and the "CEM" from this string for setting two variables.
I can read through the string character by character but this is very cumbersome. Is there an easier way to do this?
Thank you.
#2 2018-05-18 13:18:45
MustaphaC
Re: Parsing program message strings
Hi!
You have GetCommentString which can get the comments into a variable, for example in sin840d.ctl it is configured in "Start Of Block processing" with OT="CommentString".
Once the comment is read, "(T217 CEM)" in your case, you can the function INDEX to find "(" and ")" and " " then use the function SUBSTR with the INDEX's found with INDEX function
