#1 2018-02-22 20:46:38
RDawson
NX Rigid Tapping Errors (Feed per rev doesn't match pitch)
I'm using Vericut 8.1 thru the NX interface and can't figure out how to avoid getting this error. I can't place a spindle marker in my machine control statement because the posted output will be incorrect. I've set "Tool spindle always on" in the project tree, but it doesn't help. Has anyone found a solution to this problem? Everything else is working correctly except for tapping.
This is the .cls output:
TOOL PATH/TAP-.5-13NC,TOOL,T19-.5-13NC-TAP
TLDATA/DRILL,MILL,0.5000,0.0000,2.0000,180.0000,1.7500
MSYS/0.0000,12.0000,2.0000,0.0000000,1.0000000,0.0000000,-1.0000000,0.0000000,0.0000000
$$ centerline data
PAINT/PATH
PAINT/SPEED,10
PAINT/TOOL,FULL,1
LOAD/TOOL,19,ADJUST,19
DISPLY/()
$$UDE: TOOLSTATEMENT/STATUS=ACTIVE
DISPLY/RIGID TAPS BOLT HOLES
DISPLY/()
COOLNT/FLOOD
PAINT/COLOR,186
RAPID
GOTO/5.9933,4.1401,2.0000,0.0000000,0.0000000,1.0000000
CYCLE/TAP,RAPTO,0.1000,FEDTO,-1.0000,RTRCTO,AUTO,IPM,100.0000
PAINT/COLOR,31
GOTO/5.9933,4.1401,0.0000
CYCLE/OFF
PAINT/COLOR,186
RAPID
PAINT/SPEED,10
PAINT/TOOL,NOMORE
END-OF-PATH
This is the actual .nc output:
(.5-13NC HSS TAP .375SDIA 1.75 MIN LOC 2.0 MIN STICKOUT)
(HOLDER - ER16 COLLET HOLDER 4.0 LONG)
(OFT NO. 19)
(RIGID TAPS BOLT HOLES)
G0 G90 G54 X5.9933 Y4.1401
G43 Z2. H19 M8
M29 S1300
G84 G98 Z-1. R.1 F100.
G80
G0 Z2.
M5
M9
M98 P1
M6
M30
Ron Dawson
Ducommun AeroStructures-Parsons
Engineering / NC Programming
