Hello all,
I am new on this forum.
I have GROB G320 machine with two spindles and two B rotary tables...
Need to edit two Stocks to be activate in simulation...How can I edit second Stock?
Hello,
you will need 2 spindles and 2 tools in the machine tree.
I think for the kinematic of your machine you also need 2 separate Attach components.
Then 2 Stock components: one in each attach.
To tell VERICUT that both tools must cut, go to the G-Code Processing > Events > Reset > SubSystem 1 and add this macro: "SetVcMultiTools" with override Value = 1.
In version 7.4 you can visualize both Stocks in 1 workpiece view: right click > Display Stocks > All Stocks.
I hope this helps.
Kind regards,
Lesley
Lesley Morsink
ASCO Industries
TDM 2017 - CATIA V5 - ICAM CAM-POST- MACHpro - VERICUT 8.0.4
Hello Lesley,
Thank you very much....it solved my problem.
Regards
MKoňařík
