#1 2015-10-21 16:19:04
tsaladyga
Undersized Holes
Good day all,
I am running Vericut on parts that we programmed 1100+ holes in. Although I have succesfully caught holes that were off in position or set too large for circle interpolations, I have not been able to catch holes that are too small.
  That is to say, if I have 30 holes that are .256 +/- .005, is there a way to set Vericut to catch holes that are coming out let's say .249?
Any help would be appreciated.
Todd
#2 2015-10-21 20:16:20
Verifun
Re: Undersized Holes
You can try to set your cutting tolerance I bit tighter and then Auto-Diff will be able to spot it., using excess method.
Make sure to export your design model with a tight tolerance as well, otherwise the holes will become coarse facets and that may influence auto-diff as well.
