#1 2005-10-13 08:12:59
Svante
Variables in Siemens 840D
I have a problem with for example $P_UIFR[1,Z,TR] as work offsets. This word and all corresponding as $P_UIFR[5,Y,TR], $P_UIFR[3,X,TR] are defined as Macro, sub type Numeric. Nothing here is changed from the Siemens 840D template ctl-file.
A bit of the tool path looks like:
$P_UIFR[1,Z,TR]=395.73        (this is the fixture height, just read in, not activated)
G54                                      (activates the 395.73 as a workoffset)
$P_UIFR[5,Z,TR]=$P_UIFR[1,Z,TR]
$P_UIFR[6,Z,TR]=$P_UIFR[1,Z,TR]
Those two rows makes the problem: I can't get the value (395,73) out from $P_UIFR[1,Z,TR] and get it into $P_UIFR[5,Z,TR]. Vericut thinks that everything except a 1-9 after the "=" is zero.
I have tried different ways with different result, but haven't succeeded all the way. I hope this should be simple??  yikes
Anyone?? Please!
Thank you!
Best regards,
Svante
Svante Eriksson
System owner
#2 2005-10-19 13:20:31
Svante
Re: Variables in Siemens 840D
I have now solved this issue... big_smile
Svante Eriksson
System owner
#3 2007-05-31 19:28:18
blampman
How did you solve this problem???
I am having the same issue with an 840D I am currently setting up.
