#1 2005-10-11 13:42:38
balogh
Sinumerik 840D type tool offset
Hi All,
Sinumerik 840D (and 840C) controllers use separate D word range for each tool for tool offset. I mean if I use T1 I can define D1; D2  etc. different tool offsets for this (T1) tool and can be done the same with T2.. and so on. How can I handle this in Vericut?
(I found a solution for D1 for all tools, because I overwrite the D1 with tool number, but it does not handle the higher offset numbers.)
Do you have better solution?
Attila
#2 2005-10-11 17:40:39
Re: Sinumerik 840D type tool offset
Set your control like this:
Then define a table for each tool offsets:
Setup > G-Code > Settings; Table tab
Add/Modify
Table Name = Tool Length Compensation
Register = [tool number]
SubRegister = [offset number ex. D1, D2]
If the table is not defined, the offset will be the gage length defined in Tool Manager.
#3 2005-10-12 07:03:20
balogh
Thank you.
But unfortunately I did not find these macros in v5.3.1.
Is it available only in newer versions?
#4 2005-10-12 15:23:33
These macros were implemented in VERICUT 5.4. To see all the new features in VERICUT 5.4, you can consult the release notes:
http://www.cgtech.com/PDF/v54_relnotes.pdf
#5 2005-10-13 13:02:32
balogh
Thank you!
(Do you know a workaround for VERICUT 5.3?)  sad
