7.3.1 - I'm trying to machine soft jaws which are defined as a fixture component.
Collision, "Visible Fixture and Active Tool's Cutters" is deselected but I'm getting Error: "Tool CUTTER" collided with "Fixture..." at line: (...) X...
What am I missing?
If you want to remove material i think you'll need to move your model in "stock" branch.
Check Configuration > Machine Settings > Collision Detect and check to see if there is something there that causes the error reporting.
Visible Fixture and Active Tools Cutters checkboxes work as an override for the main Machine Collision Detection table, so the user can easily change the values without having to go and edit the Machine Collision Table.
