#1 2005-08-31 12:39:34
Carlos
setting up berthiez turn center
Has anyone had much success in building and setting up  berthiez turning centers? :?
#2 2005-09-07 16:09:06
Al_V
Re: setting up berthiez turn center
Never heard of those, but look through the sample files, and pick the closest one, then "save as" or copy and start changing.
Austin NC APT administrator.
and other ANC applications.
#3 2005-09-07 20:45:59
The Berthiez I have seen were Vertical 2 axis Lathes with NUM controls.
In the Library folder, there are some files you can use to start a job like that. The machine does not have any models, only the kinematics. It does not matter if it is a horizontal or vertical machine since both will cut in the XZ plane. The control is a NUM.
File > Open; Shortcut= CGTECH_LIBRARY
file = num2x.usr    (num2xm.usr for metric)
