what is the best way to save a stl file from vericut after the file has been run, I want to use it in my next operation in a mastercam session.
it seems to take forever to save, it also looks terrible and I have no idea where in the heck it is saved to coordinate wise?
File > Save Cut Stock > STL
You could try reducing the triangles. It will also be output by default to the Active Coordinate System, change the active coordinate system if you want something different
Remember also that the model you are exporting has to be good to start with, garbage in garbage out. Check that File > Properties > Stock Consistency Check is checked as well
While Vericut is a master manipulator of STL files, trying to save a cut stock STL is not something it does well.
Michael Stevenson
Vericut Programmer
PCC Aerostructures
While Vericut is a master manipulator of STL files, trying to save a cut stock STL is not something is does well.
Improving quality and minimizing size of output .stl files, an enhancement request that has been open for a very long time.
Moderator It seems to me, you are right
