I'm configuring an Okuma U100L lathe control, and I need to macro to know wether the active tool is a turning (grooving) tool or a drill.
With the Okuma control, G74 can be used for a grooving cycle, or a chip break drilling cycle. The parameters for this cycle are the same for both grooving and drilling (so I can't set conditions based on codes present on the cycle line).
Is there a way that Vericut knows if the tool is a drill or a turning tool? Can I extract this as a variable of some type?
New Zealand Vericut Reseller
You can add SetDynamicVars to Start of Processing with an override text of CurToolType 9999.
Where the 9999 is a variable that will store the tool type.
It will return a value :-
1 = milling tools
2 = turning tools
3 = probe
4 = tap tools
5 = waterjet tools
6 = knife tools
7 = polish tools
Thanks Tony, that was a great help ![]()
