#1 2014-06-01 23:50:29
wartron
Color of Design model with Section view
Hi.
I recently updated VERICUT 7.3 from 7.2, and I've encountered a problem with using 'Section view'
With the old version, the color of design model remains its inherent color, so I can identify design model in the cross section.
But after updating, the color of design file also set to section color that I cannot identify design from stock.
ex) If I set the color of design model to green and the color of cross section to violet,
then I make section view and run simulation, cross section of design model goes to violet color.
With the old VERICUT, cross section of stock is only shown in violet and section of model remains green.
Is is some change in v7.3 or I missed some pref. settings?
#2 2014-06-02 09:10:11
MustaphaC
Re: Color of Design model with Section view
Just tested with standard project and still see design embedded inside the cut stock after section is done. Did you try to refine the view?
FluxBB bbcode test
#3 2014-06-16 07:54:20
wartron
Thanks alot Mustapha,
Yes, I tried to refine view, but I still cannot see the section of design inside the stock model.
Surely, I played the simulation some steps..(I know I cannot see design inside the section view when the simulation is not started)
Did you tested this with Vericut v7.3.1 or other (lower) version of Vericut?
Or... are there any options related this? please anyone help me.
#4 2014-06-17 07:43:39
MustaphaC
I did the test with V731 and you are right the design takes the same color as the section color. I did not realize that I did the test with V73x pre-release, sorry... So it is fixed. And before you ask smile there is no due date for the next release
#5 2014-06-18 04:35:03
wartron
Here is screen capture, Upper one is v723, Lower one is v731
Both you can see 'Cut Stock' and visible Design Models. I did set different color for design and section.
SectionErr
