When we run our sim for any machine, the work piece is "pixled" and cant see the cut in action per se. The fixture and the machine componets are crystal clear can I improve this? Everything looks fine untill I push play. It is a seed file that I have used sense I have began programming so I know how to use the sim but not about building machines or the real nuts and bolts of vericut.
"3 people can keep a secret if 2 are dead." - Benjamin Franklin
This behavior is normal in the Machine/cut stock window. The size of pixelazation can be controlled by View > Attributes > OpenGL settings > Cut stock display
The slider controles display quality vs simulation speed.
For an accurate cut model use/add a work piece view to your simulation.
That worked thankyou so much.
