#1 2013-05-27 12:13:54
igor
Batch to Importing multiple DXF files
Hey guys, someone knows how can I use the Batch to importing mutilple DXF files to Tool Mangager, that is avaible in Vericut 7.2????
I try to write in prmpt command but doesn't works.... sad
"A new batch command is added to enable importing multiple DXF files into Tool
Manager.
toolman batch input_dxf_file=drive:path output_tls_file=drive:pathfilename.tls
cutter_layer_name=nnn holder_layer_name=yyy tool_type=mill|turn
units=millimeters|inches control_point=tip|origin"
I found this in Release Notes - Vericut 7.2 Enhacements...
This tool works right????
Anyone?
Igor Freitas
CNC programming
GROB - Brazil
#2 2013-05-27 21:03:16
Verifun
Re: Batch to Importing multiple DXF files
Igor,
The first thing we would need to know in order to help you out is the error you are getting...
Daniel
