In v7.1.5 when you slow the speed down, you could hit the down-arrow and slow step through a given line...since I installed v7.1.6, that doesn't seem to be working. I don't know if it's a glitch or if maybe I just checked/unchecked a setting to make that work again. It is extremely helpful to me, and I would really like to get that back up and running again.
Thanks for any input!
Mike
Hoppe Tool
The arrow down command was causing some conflicts with some menus, we replace it with the [+] key. This was changed in 7.1.6 as you observed.
This is very useful indeed, by moving the animation slide to the left, the [+] key allows you to step at all intermediate points.
Serge,
Thank you Thank you Thank you!
As usual, you have saved the day!
Mike
Hoppe Tool
Let me add my thanks to this as well!!
Is this in the Help Docs?
John Joyce
Barnes Aerospace
Windsor, CT
The help is very large an always in progress, when the green light is given to release the software, the help is is packaged with as much of the information updated as possible. But we attach a document called Releases Notes which contains all the fixes, changes and improvements contain in every point releases of VERICUT.
This feature was not directly documented:
I found a note about the change "The Down Arrow key now works correctly for navigation through menus". The problem was that you could no longer navigate through the menus if you were in the intermediate step mode.
I have notified our documentation department and this will be added to the next release.
Thank,
