Hi all,
Could someone help me how to tell Machine Sim put error if program has the wrong H value?
Dnguyen
The way I have it is for the tool number and the H number to be the same- T4 should have H4. This way, in the Registers section of the G-Code Processing window I set H* to give an error if the values are different.
Mike
Hoppe Tool
Thank you Mike,
How you set the Condition for the H* if T and H value is not same?
Something like this below:
Condition Conditional Value
H <*
H >*
Macroname = ErrMacro
dnguyen
I set the Condition for H value some how it doesn't seem working right, please tell me what i did wrong
Operator = and
Type = Word
Condition = H
Condition Value = <#4120
thanks
Here is what I had done, and it works.
Operator = and
Type = Variable
Condition = 4120
Conditional Value <> $
Macroname
MessageMacro Value=2 Text=The T and H do not match.
StopUnconditional
This way you not only get an error but it will stop no matter what. Depending on how big of a problem this isand how much of a pain you want this to be you could also set a variable #5999=1
Then in your G00/G01/G02/G03 you could add a condition for this Variable if it is equal to 1 to give the same error as above. This way running this program thru Vericut is so painful it will have to get fixed immediately.
Gentlemen,
there is a simpler way to detect non-matching H words.
Configuration > G-Code Processing...
Expand the Events branch
Expand Start of Processing branch, SubSystem:1
find the macro GageOffsetAttributes
Right-click, Add/Modify
Change the Override Text to: 110000100
each number can be 0 or 1, the second attribute is to output an error if the H number does not match the tool ID
If you have your cursor on the macro name and press F1, you get the description of the macro and all its options and some examples.
Is there any documentation detailing what the vericut macros do and how to configure them correctly like the previous example?
If you hit F1, it will open the Vericut Help. Open the Vericut Macros section, and that will give you all the different macros with explanations and what ever other inputs you will need.
Also, if you open the G code Configuration window, and click on any of the macros programmed in the control, and hit F1, it will bring you directly to that macro in the above mentioned explanations section.
Mike
Hoppe Tool
