Dear all,
I found an incorrect error pop, it is below
Error: Tap cycle feed advance "160" is incorrect for tap tool "310" loaded in component "Tool" at line: (3926) N8G99G84X0.0Y0.0Z-22.R-76.85F160.$
but my NC code is no problem, they are below:
N4S200M3$
N6M29S200$
N10G80$
Seems that the pitch of the cycle is not matching the pitch of the threading tool.
Hello Stefan,
I found it is no problem on pitch, you could see the pitch parameter in the picture attached below. That is a little strange.
Hello Vincent,
What is the feed rate in the Info > Status window?
is it 160 MMPM or 160 MMPR?
Hello Vicent,
I hope this will help you.
I have already faced this message on Vericut and did the following (we're still running v7.0.3):
Go to "Configuration > Word/Address" and locate the word "G84" under the "Cycles" group...
Expand this word and change the default macro "FeedModeRevolution" to "FeedModeMinute" ...
See if it helps you.
Regards
Rodrigo Camargo
IT/PLM Specialist
Thank you all of your replays, now this problem has been resolved. those are very useful informaton.^v^
