Hi All:
Does anybody have any issues with 'Fast Feed' check in a project created in V7.0.3 ?
Regards,
Zac.
Can you be a little more specific? what kind of issues?
Mike
Hoppe Tool
Something like the value is not taken unless the session is reset or the value be re-entered after the cycle starts. Not accepting the value in a " Change Fast Feed Value - rewind - run" scenario.
Works ok in a " Change Fast Feed Value - rewind - run - Stop after a few lines of code - reenter the FastFeed Value again - Hit Enter - run" Scenario.
Regards,
Zac.
I have tried all kind of scenario and could not reproduce your problem. :?
I used the released version of 7.0.3, I used vericut.vcproject from the Library folder.
can you reproduce it with any files?
Thank you for the reply:
1. Can I reproduce it with any files?
... Yes. But what is funny about it is that it is the only file. I tried Fast Feed with other project files created using V7.0.3 and it works fine. So I guess it is something related to that particular project file and not having anything to do with the release of V7.0.3
Regards.
Zac.
