I am trying to simulate Dynamic Offsets on my Variaxis 630 5X II. I am using the Mazak Matrix control from the Vericut v7.0.3. library. How can I make it so that when the pickup is called (G54.2 P1) the machine doesn't move until a motion is called. For example, if I put a line:
G54.2 P1 X0. Y0. Z5.
the tool rapids to that position. If I only call the pick up (without x/y/z) the tool seems to be ok, unless the table is rotated, in which case the tool rapids to the distance from the pickup set in the G10 line.
I need to be able to call the pickup, and have the tool stay where it is until I tell it otherwise.
I'm sure this is just some setting that I am missing, but I would rather not just click around like mad and risk messing things up if I don't have to.
Thanks in advance!
mike
Mike
Hoppe Tool
I tested this with the mazatrol_matrix.ctl control from the library folder (version 7.0.3) and it
worked as expected (it did not move without the axes commands on the line). Take a look at
the Start of Processing events...
Configuration, Adv. Options..., Events tab, Start of Processing
look for
DynamicWorkOffsetsWithMotion
and make sure the Override Value is set to 1
Best Regards,
Dave H.
Thanks Dave!
I will give that a shot
Mike
Hoppe Tool
That took care of the problem...
Thanks again, Dave!
Mike
Hoppe Tool
