#1 2010-05-17 11:56:06
Saving a read-only controller
Before V7.0.3  lol
When saving a "read-only" controller, Vericut shows a file selection box because it can not overwrite this read-only file.
In V7.0.3  yikes
When saving a "read only" controller, Vericut messages "Control file Saved "xxx"", indicating that the controller was saved, while it actually is NOT saved!!!!
#2 2010-05-17 23:43:09
Re: Saving a read-only controller
When you save an encrypted control, you are saving the current control and you are creating an encrypted version at the same time. You get a control with the .ctl extension and another one with the .xctl extension.
The current control referenced by the project remains the original control (un-encrypted). Therefore you can override it. The encrypted is not automatically loaded, this is by design.
If you open the .xctl encrypted control file in your session, you will not be able to override it. you will get the message: "Control modification not available because an encrypted control file is used in current setup"
#3 2010-05-17 23:49:23
OK, I completely misunderstood your initial posting, but I will leave my previous answer because it contains some good information.
you are talking about the file permissions that are read-only. I tested and was able to reproduce the problem. I will report the problem.
